Startup initialisation
Marcel FAGNOUL shared this question 12 years ago
How can i set virtual switch after a reboot of the box.
Same question to set variable .
Thank's
Under The settings of the virtual switch you have an URL, use that.
For variables you have create a dummy rule.
Zipato is building a solution to store all data and to get them back after reboot. I'm not sure it's 100% yet but some parts are there,
State of the virtual devices should be already restored after reboot. As for the variables, they will loose their values after reboot.
how can i activate a rule at startup, only activator can be use as an event in then when clause
i want to alway switch some device on OFF after a reboot or an upgrade of the box, how can i do ?
Does all the rules are done after a reboot ?
I think not in 0.9.998, but in some topic i had read that is done ?
