Help with virtual switches
JB shared this question 12 years ago
I’m now learing to use a virtual switch and have a question. I have made a simple rule, when the virtual switch (action) is toggled I want to toggle a light – but nothing happens. I can see the event ("Live…" ) but nothing happens.
What am I missing?
Replies (6)
So when virtual switch is on then turn on Lamp x?
When virtual switch = on
Lamp x action on
I guess he want Virtual Switch ON or OFF (toggle)
Lamp X action on
I have never used ANY (toggle) with the virtual switch but i guess it should work.
I have made some progess but I have a new question...
I have created two virtual switches, both are configures (type) as HTTP devices. Both of them appears under “Lights & Power (Control Center) – so far so good but when I manually toggle them (on/off) switch nr 1 report an event as state changed to true (or false) but switch nr 2 report an event as state changed to on (or off).
Why do the switches report different values (on/off vs true/false)?
Are you sure you used the same actions in you rule?
I mean, sometimes you have the choice between on/off and true/falseCan you check both rules and verify it's the same?
Otherwise I don't know why you get different events in log.
And what is the difference between on/off and true/false ?
Mick
Nothing, this is a bug.
