CooLinkHub
i know you are compatible with coolmasternet but you are compatible with CooLinkHub .
you can check these link :
https://coolautomation.com/products/coolplug-coolinkhub/
check the attachment
Regard
CooLinkHub.pdf
I would like to inform you that CoolLinkHub is not supported in Zipato platfrom.
Zipato platform supported Intesis Wmp WiFi Bridge. You can used this gateway.
https://www.intesis.com/products/ac-interfaces/wifi-gateways/universal-ascii-wifi-ac-is-ir-wmp-1?ordercode=INWMPUNI001I000
how can make support , because I have project need integration with cool link , you have any way for these .
Hi, it could be possible to add it remotely if your device can be added under generic descriptor. After that we need a technical specification of that device in order to create its descriptor accordingly. If it doesn't work, it is required to send us your device. However, for any particular issue (like this one), please open a ticket and our Support team will check if it is possible to add support for your device.
