Secure SCS317 and Zipato Rule creation
Slashroot shared this question 12 years ago
I have the Secure SCS317 with the Boiler Actuator Unit and i am busy with some rules and keep on running into issues.
What i try to accomplish:
-When Alarm is armed temperature should go to 14 degrees
-When Alarm is disarmed the temperature should go to 22 degrees
This seems part works but the problem is that the device itself has its own schedule (kept it default and it has 6 programs-settings for each day) so even if you would arm the alarm it will set the temperature to a different value.
To make it even worse the device + actuator/boiler is added to Zipato and temperature is also configured here (3 values, night, day and evening)
I have attached my configuration and would like to know if someone can help to get the system working so the temperature is kept at 22 degrees when Alarm is not armed and 14 degrees when Alarm is armed.
Thanks in advance
regards,
Slashroot
