Two zipabox on different location's
ginwah shared this problem 12 years ago
I am trying to install my second Zipabox, this will be in my second house.
To switch between the two boxes on a laptop/pc is not a problem. However, there is no possibility to switch on my iphone/ android phone. Can you make this option?
regards,
Gin Wah
Hello, this option will be added with the next firmwares on both Android and iOS application
Replies (12)
Sebastian,
Thanks for your quick response.
currently I only can see my "second" zipabox on iphone/Android, which is very inconvenient. Since I am still in my first house. Tried "controller shift" but this takes long time and turns out not successful. How can I change it back to my first one? 010070200D018BDFWhat will be the current work around to keep one zipabox main(access phone and laptop) and one secondary(only access laptop)? I have to install My second zipabox next week.thanks in advanced,Regards,Gin Wah
Only thing you could do is to use local instead of remote (this should display the current one you are at), but that means i will find your local Zipa and if remote was at that moment the same you can't connect remote until you are in your other house.
Or wait for the ImperiHome App...it's coming soon.
HeroS,
With Imperihome I sytill have teh same problem. It only find/reconise one Zipabox.
Is it possible to move one box to a new create a account?
regrads,
Gin Wah
You got the same account on both boxes?
HeroS,
Yes I have both boxes on the same account. At the beginning I thought it is handy to have both on the same account since you can switch between both boxes when logged in via laptop/PC. However, this switching option is not available in both apps.
Local is not working as good. I can't get connected via local mode.
Switching between boxes will be available in the new version. You can find ti within a SETTINGS.
Both APPs will be available this week.
Hi Sebastian,
Is it available now?
+When will you repair local connection?
Yes, it is available both on Android and iOS. Once you login, go to settings and you will find Zipabox button...
Local connection is also working now on both iOS and Android.
You are awesome thank you Zipato team.
