Z-wave signal weak
Etienne Lebon shared this problem 12 years ago
Not a Problem
I am starting with domotic and zipato, but it seems that signal is weak and far from specs (30 to 50 meters). i would rather say 10 to 20 (inside/ outside). What can i do to increase it. A new high antenna ?
standard Z-wave range in practice is around 20 meters. Sometimes you can get it longer but the conditions must be perfect. It very much depends of obstacles (walls, doors, wireless signals...). In case the signal is less then 15-20 meters between all the devices and Zipabox, than we should check out the antenna on the Zipabox.
