Replies (24)
Will this device be supported by Zipabox?
Just kidding :) It's a good news.
Yeah yeah yeah ;)
Retailers are saying the product is coming in April.
Any videos or reviews yet?
Looks nice, but 59 euros for a lightbulb?
A philips HUE is the same price. So it is a normal price for these kind off bulbs.
how to trigger exclusion mode / factory reset on this device? I dont have any other zipato products. I want to pair it with my own zwave board.
Add a new device with zipabox
triple tap the bulb to wake it up
click RESET
wait
done! ;)
I suppose your zwave board support this functionality too, but you can simply reset it with zipabox
I don't have a zipabox. And the bulb does not activate pairing mode when I tap it. I cannot switch it on, I cannot reset it, nothing. I think it is paired with another controller. So I have to exclude it. But how to activate exclusion mode?
If you take a look at your bulb manual (included in bulb packaging), there's a chapter init titled: HOW TO ACTIVATE INCLUSION OR EXCLUSION MODE.
And it says this:
  1. Inclusion and exclusion modes are activated by gently tapping the light bulb. The light bulb will shine green to indicate a successful activation of inclusion or exclusion mode.
Thank you for pointing this out. I think I am missing this manual. There is only one quick installation guide, where I could not find this information. Additionally my bulb seems to be broken. When turning on (power switch) it flashes shortly white once. Then nothing happens. No green shining when I touch it.
It's not enough to touch it, you have to tap it or flick it to activate the shock sensor.
stock-photo-hand-about-to-flick-an-egg-58511564
Yeah! Thats it! :) Thank you!!!
Well, I am kind of confused. I've got two different manuals. Both are telling me "Quick Installation Guide 1.0", but they differ. They are telling me about different supporting command classes. Also one of them does not include the "inclusion/exclusion mode part" Tomislav was talking about. Nevertheless, my inclusion went fine now. Can anyone tell my which zwave commands to send to that bulb for using the 5 different color channels? :)
ZWave Color Control! Found it by myself. Thanks for supporting me here guys! :)
Hello, I'm using a Razberry and was able to include, switch on/off and dim the bulb, but as everyone, I was not able to manage colors. Has anyone found the commands to manage the colors ?
There are command classes for color controlling. What exactly have you tried?
I can't figure how to use the commands to change the bulb color. I only see it as a white bulb in my Z-Way server.
I don't even know what commands to use...
There is a command class COLOR_CONTROL. The hex-command of it is 0x33,
subcommand COLOR_SET 0x05 lets you set the values. Since I do not know
your setup, I cant give you detailled instructions. I developed a zwave
application for an embedded system. It is able to use the functionality
of the Zipato RGBW bulb. All you need is written in the Z-Wave
documentation shipped with the SDK!
Thanks for your explanation. I don't have the zwave sdk documentation, is there anyway to get a download link for it ?
I'll try to get it work in my setup (Razberry + HomeGenie)
Documentation is only available under NDA if you pay for the SDK!
I was able to set the color temperature from my HomeGenie setup, but still trying to figure how to use the command COLOR_CONTROL.COLOR_SET, not sure I'll be able to make this work. Unfortunately, ZWave SDK is a bit expensive for an amateur like me ;)
Smillier what did you do to be able to set the temperature from Homegenie.
how to use it with VERA UI7?????
