MQTT help
Andre shared this question 6 years ago
I have installed MQTT and everything works perfectly but I still have a problem. My zipabox is behind a second router and it does not see the MQTT broker if it is in the same subnet. I have to install the broker behind the 1st router. I entered an address like this : tcp : //192.168.0.X in configurataion of Zipabox. My zipabox has an address 192.168.8.X. I searched for a long time and did a lot of unsuccessful manipulations.
Perhaps I have to enter a different tcp adress for resolving ?
your help please
Thank you
The address should be tcp : //192.168.0.X:1883 instead of tcp : //192.168.0.X. Assuming that 1883 is the port of your MQTT-broker
Zipabox and the broker should be located on the same subnet, if they are on different subnets, you may need to configure routing on your router.
