how to get Alarm status notify?
Simone Biagini shared this question 12 years ago
Hi!
there's a simply way to get a notify about alarm status without check the web portal or the smarthpne app?
I'm thinking about a light, a speaker.. but all of these involve the use of a relay.
Something about a tweet-tweet sound or a quick blink on arm/disarm and something like a regular blinking of a led/light every xx seconds?
It's possibile to make a rule that blink the siren led every xx second (like 10sec) without activate the alarm?
You can use the Squawk for this:
If you go out of home, and use your key fob to arm/disarm the system, you won't be able to see or hear any confirmation signal from the alarm panel. This is why Zipato allows you to use as many actuator devices in your home (e.g. lights) as you want, to give you the signal when successfully armed or disarmed.
>> Go to Alarm panel >> Edit partion >> scroll down.
Als u can make a rule like this:
When Alarm=Armed
Action Light x = on
Wait 1 sec
Action Light x = Off
Wait 1 sec
etc
Ok. Great.
The rule it's ok for the light (I'm thinking about a blink
on a rgb led tube installed outside as entry light, red blink on arm..
green blink on disarm ).
So the "Squawk" is a function that "pulse" a sound from siren?
many thanks.
Not only a siren (sound) but also a light ...it turns off/on 3 times.
