Rule creater Fibaro roller Shutter 2
Bboekelo shared this question 12 years ago
Hello, i have a roller schutter module from Fibaro and he sent a signal to the screen. But behind a switch i have another shutter module to send the same signal to the fibaro module at the screen. The reson from that is that i kand reach the switch from the shutter whith a control cable and i want to use the house also whithout the mobile phone or computer.
Do you have a good solution for this problem. i'am thinking about a rule bud the rules that i have try do not work
Hi. I saw this old question. Did you ever find a solution to this? If I understand your question correct, you want to control the Fibaro Roller Shutter from another actuator behind a physical switch where there is no way you can cable the physical switch to the Roller Shutter. Right?
