how to use pressed 2 and 3 times on the FGS223 Double Switch
Dimitri Van Hove shared this question 6 years ago
It seems that on the FGS223 Double Switch i don't have the pressed 2 times , pressed 3 times and hold in the controlleron the rule creator
I have also single switches and there i can shoose the pressed 2 times and 3 times ?
Settings ? can't figure it out.
if found the solution , in your module manager go to your z-wave device .
And see where your scene inputs are, are shown, click on the wheel and active "show as device"
then you will see the device under controller in the rule maker. thx
/14166e740a094e0ac2e6c3743e6c16d8
It seems tha tyou need to user Scene ID's ,
the ID's are enabled but i can't choose or set the id in the rule creator, does someone know where this sits ?
Fibaro FGS223 has in configuration parameters 4 options and all of them can be activated in order to enable scene sent events in the rule creator. To change activated options, please click on its buttons and press Send command to update configuration parameters in the fibaro device (please wait to receive confirmation message about updated parameters from the device).
After that using of scenes IDs will be possible in the rule creator.
Hello Dino,
i tried that but nothing showing up in the rule creator under controller.
/2f3672c5ba015025344594ad022e69fc
please check if you add correct endpoint under When block - it should be endpoint selected under Control Device type
where can you do that?
Same question, and if there is no endpoint , how can we add them ?
