Fibaro Roller Shutter 2 just being recognised as CLASS_B_MOTOR_CONTROL
Olato shared this problem 12 years ago
Hi!
I just have succesfully added 2 Fibaro Roller Shutter 2 to my network. This worked fine and they were recognised as Fibaro Roller Shutters.
However, I added a third shutter and this one is just being recognised as "CLASS_B_MOTOR_CONTROL". In the Device Manager this is listed as Fibargroup 769 and all the configuration options that Roller Shutter 2 has are missing.
This is what I tried further:
1. I removed the device and readded it, but still the same problem.
2. I tried adding a 4th device, also the same problem.
3. Then I tried removing the 2nd device (which initially had been recognised correctly) and readded it. Then this device also was just recognised as CLASS_B_MOTOR_CONTROL. This tells me that this problem is not depending on the device but probably is something in Zipabox.
If you have any ideas how to solve this, I would be happy!
Many thanks.
Cheers,
Oliver
Greetings,
Please open a ticket at http://support.zipato.com/
Can you please share the solution to this problem?
