Status change from Zipato box is to slow
If I change switch off - on, the switch will switch back to off. Lamps are still on.
After more then 5 sec the status is on.
Same problem here
Same problem here
Scheduled events hadn´t been run properly this evening.
It shouldn't be a problem any more. It was an issue with the servers, which caused some delays.
