Virtual Weather Station - ICON / Cloudiness
Florian Hutter shared this question 6 years ago
How can I get ICON information also cloudiness information from virtual weather station?
there are two attributes
  • ICON
  • WEATHER_ICON
which is the right one?
and which values are available?
I want to create rule for roller shutter to move up if weather is cloudy / not sunny.
i got it i have to set string as wi-yahoo-## and ## is the number
Is it possible in this way? I don't received a test notification yet
Also in case of definition time between sunrise and sunset. Is it possible to do it in this way with virtual weather station? I also didn't received a notification yet.
if you check event logs for WEATHER_ICON attribute, you can see its values - see fir. If you set those vlaues in the rule creator, it shoudl work.
ICON attribute is not used by Yahoo - there is no event in logs.
yahoo weather codes are beyond of Zipato scope so please check it by yourself - here is a link where you could check them - https://gist.github.com/Kepro/9ea2a918fd6f0a58b474
/94d21223e1644de601fce09003c2123b
that right?
ut should be set as "wi-yahoo-##"
it means i have to set e.g "wi-cloudy" as string into the rule?
