Thermostat: The Away Calendar is in English
Guest shared this idea 13 years ago
How to reproduce
  • click on the configuration on a thermostat
  • Click on away
  • Click on the small calendar to set a start date (for example)
Actual behavior
  • The text of the calendar (for example the month) is in English
  • The day are sorted in the English way, the first day is Sunday
Expected Behavior
  • If the user set French then
  • the text shoudl be displayed in French ;)
  • the first day should be monday
If you use an API it should be easy and automatic ;)
