New iphone app not working as expectef
benjaoui shared this problem 12 years ago
Module status si not correctly reported: when i turn off a light it actually turns off but the status is not reflected on the app: the light status turns on again. Same thing with some roller shutter. It is corrected a few minutes after.
It is not the first Time we have that kind of problem. It was also the case a few times before with virtual switch
When Will you have an app that definitely works correctly?
I'm not the first to say that but I'm tired of being a beta tester.
It was ok for a few months but lack of maturity is now really annoying
Do you still have a problem?
As far as I am concerned, status of devices if working, but I have a problem with the rgbw controller (for a fibaro rgbw). The RGBW controller's line appears 3 times in the lights and power section of the iphone app.
The main rgbw controller works (the first on the picture attached), the second only controls intensity and the third doesn't do anything at all.
I only own one rgbw controller though..
YPXYES3FizZim7uThRaB
Another problem: every time I update the application, I loose the disposition of devices and I have to reorder them. And I cannot move the main rgbw controller, it always goes back to its initial position ;(
The text in the senario is not possible to read... Is to big
