https support?
tomprout shared this question 12 years ago
I need to send a https command. Is it supported? If no any idea about how I can do?
My command starts by https://...
Thanks in advance.
Replies (6)
Note: I tested using http request action (Method = Post) but it did not work
I nedd also, is it possible ?
If you are interested, I found a way to use https requests !
Of course! Please share!
I 'm sorry but i don't have time now to write a tutorial, but the solution is to use pushinbox :
You can create an http request to pushinbox in the rule creator of zipabox, and on pushingbox website, you can write a scenario which launch an https request (using customirl services on pushinbox).
I am using this solution and it works good for me.
you can ask here if you have any questions !
I also use this method. I just wanted to know if you had a different solution.
The strange thing is that activate/desactivate zipato urls are https and can be used with rules creator and "execute http" command...
