Fibaro Smoke Sensor alarm always not ready
hello
With the fibaro smoke sensor, alarm is alway not ready
Even if i program as exit and entry zone with time and even if i program the arm state to any.
What appends?
Thanks.
Do you use the alarm panel?
I'm using the rule creator for this. Works much better and more control.
hello, i effectly use alarm panel.
it's a shame not to use the alarm panel which in my opinion is for this reason.
But when i activat this alarm with away from home, it's Ok. very strang comportement.
Can you show the config of the smoke sensor?
her is the configuration of the smoke sensor module.
Sry i mean the config in the alarm panel :)
Here is the part of the conf for zone
Here is the part of the conf for the sensors
