Valve Controller gr-105 problem
Luís Alves shared this problem 6 years ago
Hi all,
I bought and installed a gr-105 in December 2019 and it has been working with no problems until earlier today, my Vera Plus displayed the message that the “Device cannot be found”. I tried to actuate it in the Vera and it wouldn’t. Checking it, it displays a blinking blue light which I have never seen it doing.
I tried to unpair it, following the manual, but it didn’t respond to that, tried to factory-reset it, didn’t respond, it just blinks the blue light. It does open and close by pressing the button.
Any suggestions?
I advise you to ask your question on a Vera or GR Smarthome forum.
Here you are on the Zipato forum ...
It appears you are confused. The gr-105 is a Zipato product: https://www.zipato.com/product/valve-controller
You have to exclude and include the device, but do not press 3 times as described in the description. Please make 3 double clicks while excluding and including = on/two + on/two + on/two
@AP, thank you so very much! That worked perfectly, the manual should be amended.
