Possibilities for scheduling Everspring doorbell?
Duncan shared this question 12 years ago
I'm about to buy the Everspring doorbell but wanted to double check if it is supported and if it is possible to schedule the doorbell not being able to use. What i would like to do is that e.g. at night between 21.00 and 07.00 the doorbell will not ring is someone pushes the button.
However when the alarm is armed and someone enters the door it should ring (just to remind you that the alarm is on). I've not been able to have the RFID keypad make this sound so trying to find other ways to do this.
Does anyone know how to make this happen?
Replies (11)
The only thing i know is that it is not a great devices and doesn't work that great.
I'm using a Zipato RGBW bulb for this. Red flashing >> alarm on >> Green flashing >> alarm off, arming >> Yellow flashing.
I'm using skybell as doorbell (API is coming).
The skybell looks great but also expensive. Also not sure how soon the api will be available. Do you know if it can be scheduled not to ring between 21.00 and 07.00?
The option with the rgb bulb is a good one. Didn't think of that. Very helpfull.
Noproblem about th zipato Bulb. It's is a nice product.
Schedule is not possible at this time with the skybell. But it's coming.
Is the skybell already available in NL?
Just searched for the bulb as well. Seems that no one does have it in stock... To bad..
Nee, nog niet. Je kunt hem wel via Ebay of via skybell.com bestellen.
Bulb is inderdaad slecht leverbaar. Maar hij komt er wel aan.
Heb je die skybell wel aan de praat gekregen? Ik lees er wisselende verhalen over (met name veel negatief). Iets positiever zijn ze over de doorbot.
Ja, maar ging niet vanzelf. Maar met de nieuwe firmware moet dit opgelost zijn.
Komt binnenkort een review van aan op me website.
Review is klaar:
http://goo.gl/fKiMhc
Hij is besteld... Nog ff wachten tot hij er is. Als ik er niet uit kom weet ik je te vinden ;-)
Kijk net bij amazon.de daar hebben ze de rgbw bulb wel. En ook nog op voorraad
Ik heb wel interesse in hoe je die rules voor die bulb icm alarm hebt ingesteld. Kun je wat screenshots toevoegen?
