Bug in Climate
Not a Problem
Dear Zipato Team,
I am using the zipabox with 2 modules ZXT120. I have scheduled the different temperatures using the program week tab. However depsite the fact that the temperature is not changing for the entire comfort period for instance (23 °C), every hour the zipabox is sending a command SET_COOLING to set again to 23°C causing a beep from the climatisation.
Is this a known bug ? Or i have missed to configure someting.
FYI My ZXT120 are plugged in USB but with the default mode FLIRS. I had also to learn to the ZXT120 the IR code from my climatisation.
Thanks in advance for your help.
