Scene modifications not taking effect
Jacob Berggren shared this problem 12 years ago
I have noticed that if you create scenes they work fine but after you make a change to a scene the changes won't take effect.
after you make changes in Edit scene menu click save button
and then click synchronize in Zipato Control Center.
Kind regards,
Hrvoje
if you clic on the gear trying to configure the scene, (but only do that, only look at screen and do nothing) then all controls become crazy, you must reload the page because nothing show the state of others devices, when you try.
Similar problem. I deleted a scene on Zipatile and after syncing it appeared again. The same happens with the mobile app. I only managed to delete the scene in the web portal.
