Alarm Events Log with UserName
I can't have an event lo for the Alarm with the UserName.
For example, when I use the minikeypad (Zipato's one) to activate/desactivate the alarm, it should be interesting to see in the event log of the alarm or of the minikeypad:
"Zone actived BY User1" and not only "Zone Activated"
Isther a bug of a problem ?
Thanls a lot
This is more like a wish.
But you could use the rule creator to send a email.
Thanks,
YEs, I've seen this before, but it's not really usefull.
The good way was to have in the envent log the username, not anymore.
Do you think it should be available ?
Anymore, is it possible to write in a file like an event lof file each action by the rules creator instead of sending an email ?
Thanks a lot
Thanks,
Thanks a lot
I moved this post in the Ideas section and for now you can use HeroS solution.
Regards,
Hrvoje
Regards,
Hrvoje
Maybe an idea to solve my problem:
1. Creating a Virtual level meter switch
2. Creating a rule like:
When keypad is any
if user1_away then set virtual level meter swith to 1
if user2 .... set to 2
wait 1 sec
set virtual level meter switch to 0
It's all right, in the event log you have:
Virtual level meter = 1 ...
If you want any other explaination, ask me
When keypad is any
wait 1 sec
