Alarm API in local mode - /zipato-web/rest/alarms/ doesn't work ?
jb007 shared this problem 12 years ago
I want to retrieve alarm status with local HTTP API and without using HTTPS.
=> GET /zipato-web/user/init HTTP/1.1 Host: 192.168.1.110 Connection: Close
<= HTTP/1.1 200 OK Cache-control: no-cache, no-store, max-age=0 Content-type: application/json;charset=UTF-8 Expires: Thu, 01 Jan 1970 00:00:00 GMT Content-length: 123 Connection: close Server: Zipabox/0.9 Pragma: no-cache Date: Tue, 2 Sep 2014 01:08:53 CEST Set-cookie: JSESSIONID=2Jgl0qhLBxiw32Ydbd9YNj5tGMj5Sh84; Path=/zipato-web/; HttpOnly { "jsessionid" : "2Jgl0qhLBxiw32Ydbd9YNj5tGMj5Sh84", "nonce" : "uF7QqLzGURTE4XDOYvgMj4OcKELoWUNf", "success" : true }
=> GET /zipato-web/rest/user/login?username=XXXXX&token=XXXXX HTTP/1.1 Host: 192.168.1.110 Cookie: JSESSIONID=2Jgl0qhLBxiw32Ydbd9YNj5tGMj5Sh84;Path=/zipato-web/; Connection: Close
<= HTTP/1.1 200 OK Cache-control: no-cache, no-store, max-age=0 Content-type: application/json;charset=UTF-8 Expires: Thu, 01 Jan 1970 00:00:00 GMT Content-length: 22 Connection: close Server: Zipabox/0.9 Pragma: no-cache Date: Tue, 2 Sep 2014 01:08:53 CEST { "success" : true }
=> GET /zipato-web/rest/alarms/ HTTP/1.1 Host: 192.168.1.110 Cookie: JSESSIONID=2Jgl0qhLBxiw32Ydbd9YNj5tGMj5Sh84;Path=/zipato-web/; Connection: Close
The last http request return no response from local zipabox. When i tried in HTTPS, the last request is OK. Has someone see the same issue in HTTP ? Is there a workarround or an other solution to get alarm status in local HTTP api mode ?
Stef
Should it be solve in next 1.0 release ? When is plan 1.0 ?
My initial question is very simple, is'nt et ?
Is local API is different from remote API ? Where to find local API documentation ?
Same question. Where to find local API documentation?
It seems there is still a customer support problem with Zipato... :-(
