Get battery % of the Zipato Mini Keypad
David Gonzalez shared this question 12 years ago
I have bought the Zipato Mini Keypad and installed it without problems.
http://simplyconnectedhome.com/products/zipato-mini-keypad-rfid-z-wave-wt-rfidus
It works fine but Im not able to know the battery status on the interface or the API, there is anyway to do it?
This is a known limitation on our current user interface.
There are devices, like our Mini Keypad, that don't really fit into any device category currently displayed on the web user interface.
Therefore, such devices are only shown in the device manager and in the rule creator, but not on the dashboard. If the device is not represented on the dashboard, users cannot see the battery status of such a device.
We have made some adjustments to address the issue with the battery status of the Zipato Mini Keypad. Now the battery status will be visible in the "Sensors" widget.
Just rejoin your keypad and the battery status will be available in the "Sensors" widget.
Fantastic! Thank you a lot!
I have tried to rejoin the keypad and Im not able to see the battery on Sensors wigdet.
I also do not see the mini keypad battery status in the sensors widget. Is it solved or not?
But I think the battery level must be in meters widget, like the backup module battery level.
Thanks Ivan for the quick answer.
