thermostat Danfoss living connect
carlosing74 shared this question 12 years ago
Today I installed all radiators with thermostatic head and I have only the value of the temperature, I have no value if the valve open or closed and I can not activate the child lock so that children do not change, someone know how it's done, greetings.
C5HXICe6LIi5bE40EzAx
Replies (7)
a) Just curious as to why you think there should be an "on" and "off" on a thermostatic temperature sensor. Don't you just want to set the temperature?
b) With regard to child "protection" then I guess you looking for a "child sensor" ;). Don't think they are available yet..
Seriously though, wouldn't the zipabox rule automatically override any manual setting anyway - or is it the other way around?
Danfos valve shows set point, you should use it as a Heating output in your Climate widget. It doesn't show Open/Closed state. You should use Danfos with some kind of temperature sensor so it would have a temperature value of the room to compare to.
In your Climate widget click + in the upper right corner of your climate widget. You will get a window for configuring your Climate. Write the name of your Climate and select endpoints from drop down menus. Then click Save and Synchronize.
Regards,
Hrvoje
Good morning I'm not using the valve as a thermostat danfoss, because in my case the situation does not indicate my temperature, I have a multi detector Fibaro, I want to know if the instructions are operating climate and for this I need to know if the valve is open or not, secondly these valves carry a lock so that children do not change the settings and I wanted to control it from the zipato not go crazy when unlocked, greetings.
Danfos does not report Open/Closed state, only setpoint temperature.
We send the data to Danfos and it decides (based on its internal logic that we don't have access to) when to turn On/Off the heating by opening/closing the valve.
Your Fibaro multi detectors temperature sensor gives you the room temperature, you can use it as an input in Climate widget.
We do not support Child protection.
Regards,
Hrvoje
how can i use the danfoss thing without temperature sensor?
i conected the danfoss to my zipabox as a meter.
And now? i cant add under clima anything, because i dont have an temperature sensor, so what now?
Hello Roland,
you can select Danfoss radiator valve as your Heating output, Virtual Thermometer as your Thermometer (you have to add Virtual thermometer first) and select the Function you wan't (e.g. Last). That will suffice.
Regards,
Hrvoje
thank you,
i made that, and i "installed" under clima a new thermostat with that.
i told it, to heat between 5pm and 9pm, but nothing happens.
2nd problem:
i bought from osram a lightify bulb. zigbee.
but i cant connect.
there is no connect button on the bulb. to the osram gateway i was able to connect (i made reset after that)
any idea?
