mise a jours
bonjour
probleme Remonté des t ° Orégon DEPUIS Mise à Jours
merci
SVP controle des thermostat chambre bb par sonde oregon
postes en anglais tu auras une réponse ! moi je n'ai pas de sonde en 433... désolé
Had to delete and rejoin all (7) Oregon T° sensors 132N...but now it's working fine :-)
hello,
I have the same problem.
Ticket was open on zipato support.
hello,
Oregon scientific wgr800 wind sensor ok but uvn 800 uv sensor, thgr 810 thermo hygro and thgr 122 thermo hygro are out. just after upgrate 0.9.999.f to 0.9.999.1
Try rebooting your Zipabox. If that doesn't help try Deleting and Joining one of your devices again, if that also doesn't help open a ticket at support@zipato.com
Regards,
Hrvoje
Regards,
Hrvoje
It's work with this method, but it's not a good solution with update a zipabox firmware.
when rule are created with this device and when climat rules are made, they have to be redone.
It is a relatively fastitieux work. In fact, I have three temperature sensors, two inside and one outside. Moreover, the UV sensor is raised requiring a ladder to reach it. The rules are also to resume.
Here is the statement of the actions required for thermometers, hygrometers Oregon in the change order:
1) Oregon scientific THGR810: Deleting and adding hard reboot necessary;
2) Oregon scientific THGR122NX: removal and adding soft reboot necessary;
3) Oregon scientific THGR122NX: removal and addition;
Rectification of rules was not too tedious, the system indicates the rules affected by the cuts.
I am not yet acted on the UV sensor.
kind regards
Claude
kind regards
Claude
Oregon scientific THGR122NX module on channel 2 has lost about 30 syncing after recognition.
I removed and added the module unsuccessfully several times, even with changing the batteries. The unit has 20cm of zipabox. The module displays the correct temperature and humidity levels.
The other modules are functioning properly.
kind regards
kind regards
I just spent about two hours pulling my hair to get my 5 THGR810 to connect properly to the Zipabox again. If I can spare the aggravation to anyone, here's my 2 cents:
1. Start by rebooting the Zipabox
2. Delete the sensor
3. Add the sensor through "add device" etc.
4. If the sensor doesn't send any value after a few minutes, start again at step 2. Be calm, persistent, it will eventually work (it took me 4 tries for some, while I got lucky on the first try for others). It may defy logic but... at least you'll be back to pre new firmware issues.
I have the same issue here with Chacon wallplug/motion sensor and my Oregon (temperature & hygrometer) sensor.
I will try this evening to delete/add them to see if it works for me.
I will give you feedback after that.
after testing remove/add on Oregon sensor, it works fine now.
But I'd like to do the same thing with my Chacon motion sensor (CAMDT-1010) and I am not able to add it again.
First of all, I do not find the device in list of "device to add" anymore. Why it disapears?What device can I choose to add it?
Thanks.
Regards,
Stephane.
Thanks.
Regards,
Stephane.
Hello Oxbo,
please contact us on support@zipato.com with your user credentials so we can check the status of your Zipabox.
Regards,
Hrvoje
Hello Oxbo,
Regards,
Hrvoje
