Cannot control Stella Z valves since firmware 0.9.999.1
Zipabox does not control stella Z valves since firmware update, appears to only control at preset temperature of 22 degrees. even with temperature set to 43 degrees (until next period) the valves do not respond. Please can someone help
regards
ian
Thank you for your prompt response Ivan I will try that if not will contact on support.
regards
Ian
regards
Ian
Same problem with oregon devices.
Same problem here. The valve stays at 0% whatever the setpoint is. Is this really a problem with firmware 0.9.999.1?
Regards,
Anthony
Regards,
Anthony
