Configure a message in the rule creator, cant save the contact in the field "send to".
When I should configure a message in the rule creator, i select one of the contacts. After that the Rule Creator take the name away. Way?
Hi Erik,
You are doing it right. The contact you choose is selected, and listed in "New contact". Try adding more contacts and you will see all of them listed. They have a red x next to them so if you wan't to remove a contact, just click on the x.
Kind regards,
Hrvoje
Hi Erik,
Kind regards,
Hrvoje
Hello again,
the field Send to has a drop down list. When you select your contacts it displays them in the empty space under the drop down list. Otherwise you would only be able to send message to 1 person currently selected in the list.
Hrvoje
Hello again,
Hrvoje
