ZipaBox RFID Keypad
I have just installed the ZipaBox RFID Keypad and it works fine using the RFID tags.
My question is how do I manually insert codes and can the codes only use the numbers 1 to 4?
I have read through the instruction manual three times and can not see how to do this.
>> total devices >> scroll down to the RFID >> keypad >> tab config etc
Already been there to set up the RFID tags but there is nothing in the manual, that I can see, that explains where you manually insert codes.
Do I take it that you press the "Change " button and insert your code there?
If so how long does the code need to be and do I take it that you can only use the numbers 1 to 4.
If this is also the case can you use multiples of the same number or do you only get to use each number once.
Most of the time I will be using the tags with the Keypad and they seem to do a great job. I just thought it would be a good idea to also have the option of using a code incase I misplace my tag.
Can anybody help me with this?
When will you add events log?
I want to see users who come and go?
