Issue with my Virtual Switch to control radiator
Sebastien Bonnet shared this problem 11 years ago
I have an issue I need to create a virtual switch to change the state of a radiator switch.
Because when my radiator button is invensed when I switch on, it's disabled and when i switch off my radiator it's enabled.
I'm using Fibaro FGS211 to control my radiator.
You can see in attachment the rules created.
I have tested lot of combination but it s impossible for me to control my FGS211 in this case.
Any idea ?
When switch on The virtual switch, the event is send.
But no event arrive to FGS211, it's seem the rule is not interpreted.
1IlFU5M01UZtJttk1ejh
hi,
i have exactly the same problème !
does anyone has find a solution ?
Thanks !
