Control of 433 Mhz devices.
I still got many 433 Mhz that I will certainly change to Z Wave, but until I do it, will it be possible to send several "ON" or "OFF" signal to a 433 Mhz device after each other, the problem with a 433 Mhz device is that it never send back an answer if it has gone ON or OFF and to have a better chance to get it ON or OFF, sending several "ON" or "OFF" is a solution, not a really good one, but a way to get a better result.
Thanks.
Yes it´s possible. Create rules that send command several times.
You're right, I tested it again with 15 sec between and I worked, thanks for the help.
