Manual set on the Danfoss valve is overwritted by Zipabox
Not a Problem
I have my Danfoss valve with setpoint at 25° from 10:00 to 12:00 and setpoint at 21° from 12:00 to 15:00.
At 11:00 I made some manual adjustment directly to the valve to 23°, but when the valve communicate with the Zipabox (so at 11:07) the temperature is set back to 25°.
I think that is a wrong way.
The right way should be that the manual setpoint override the temperature until next period.
So if I make manual changes to 23° directly on the valve at 11.07am the Zipabox should set 21° at 12:00 (next period).
What do you think?
I think you are wrong and to me it seems logical that the box is doing what is set in the rule. Maybe adjust wake-uptime of device or just adjust your rule.
Uhmm
I dont think so... Following your logical is useful to setup new temperature directly on the valve
Uhmm
So what ever the reason the setpoint is changed the rule you created will set it back to 25; it is what you ask for in your rule?????
