Extend alarm events for rule creator
jb007 shared this idea 11 years ago
When using rule creator with alarm, only "Arm", "Disarm" and "Tripped" events are available, but entry and exit delay are used, it is not enough !
Why do not make it possible to launch action when exit begin and when entry start (see additional picture below) ?
Thanks, for your job, Best Regards.
Files: arm.png
Replies (7)
ARM AT HOME state cant be used in the rule whit a action.sUhlTyDnEOVzk4e30ydx
if you use a timer i think it will work within the rule creator
use the wait option and make the wait the same as the entery delay
Thanks, but this workarround is partial and not enough.
what's new for that ?
Like that ...
/764
Something new in normal version or pro version about my idea ?
Bonjour, il n'est toujours pas possible de créer une action sur le statu home. Est ce que vous travaillez sur cette fonction? Sinon ya t'il une autre solution pour créer une règle du genre: Quand alarme sue HOME alors fermer les volets?
Hello, it is still not possible to create an action on the statu home. Do you work on this function? If not, is there another way to create a rule like this: When alarms HOME then close the shutters.
