433Mhz devices, should not have a "turning switch" at desktop
Ismo Korhonen shared this problem 11 years ago
I have a lots of 433Mhz mains plugs.
Quite often they do not turn on when I turn the "switch" on desktop. On light will go on at desktop, but the signal failed as these products does not send their status.
So, my suggestion is that if you keep on having turning switch on desktop, please put the off signal under off text and on signal under on text.
So, it should be possible to send On signal several times. Also as these products have problems I suggest that you change the specifications sheet at these products so that you can do like this.
Repeat signal sending XX times.
Delay XX sec between signal sending.
