Convert from Vera??? Please help.
Tommy Eriksen shared this question 11 years ago
Hello
I'm seriously considering swapping out my VeraLite box to Zipabox DUO, mostly due to the rule generator that looks real sweet.
First I must say that I really like the Vera community with all the various usermade plugins.
I really would love if someone can help me out with the following questions.
1. I have a relay board, serially attached to the Vera thru a ser2net driver, will I be able to use the relay board with Zipabox in the same way?
2. I've been using some DIY modules from mysensors.org, are there any possibilities to use these with Zipabox?
3. Can I easily send make a binary switch from an HTTP call, and then read back the result, and act upon the result?
4. is the 433mhz module comparable to RFXCOM transceiver in regards to supported modules?
5. Can I send push messages to iphone/android eg. when I open my garagedoor without any costly subscriptions?
6. Finally, Is it stable???
Any ideas, suggestions really appreciated.
Tommy
