How can you "resync" the Z-wave network if a device is moved
I have a on/off swith that I moved. Since it was moved, it appears to be off line on the zipabox control center.
Is there a way I can send out a signal or something to "wake" it up?
Also is there some sort of diagnostic tool that can measure the range of a zwave device?
/Marcus
Something like "HomeSeer Z-Seer Z-Wave Diagnostics Software for HS2" would be excellent....
:D
:D
If I could just see what devices were connecting to what parts of the network then I could adjust the positions of the mains repeaters and get some stability....
you can use the Fibaro motion sensor as a signal strength meter
there are some healing functions for the Z-wave network in the zipato box.
i do not no how to use them, lack of manuals from zipato........
