controlling sonos
I want to control Sonos with MCO Home touch switch:
first button, Play and Pause a music by turning On and Off the button
second button, Next music
third and forth button for Sound Level up and down.
Is it possible?
What about using Keyfob?
Thank for your help
if you add both to the Zipato system and they can be controlled (are supported).
Then you can use rules to do this.
When button pressed
Action Play Sonos
When button pressed
Action Play Sonos
Tap and hold the play/pause button on a product to group it with another room that is playing. If you have multiple rooms playing different content, continue to hold the play/pause button to cycle through each room that is playing. Release the play/pause button and that product will now be grouped with that other room.
