RULE Engine
this afternoon all Sensors, which are Push buttons on KNX side stopped working. Have you changed something today ?
Just recognized, that the whole rule engine does not work !
try to sync rules again and check again.
May it would be better to find the problem, before i resync. Typical Microsoft solution - reboot :-)
Some funktionslos are back. E.G the KNX buttons seems to recognized and switch the lights.
But i have as well some rules doing something by night and send a message, when they run. But these messages does not come. Some rules does not work at all.
I have done nothing so far. No resysnc of rules or something else.
Due to i had this problems with the rules engine several times now, i hope you can find the failure. So i will wait for your reply, before i try to restart or resync.
Take for example rule 2 of my account. There should something happen by night an messages should be send after action. But these does not be send.
You find my SN in ticket 31612-04-16, there is the same problem as a ticket.
Kind Regards,
René
Kind Regards,
René
Last night the mails arrived. Rules are seems to work.
