FGSS-001 range detector
since a few week (month) The range detector function of the smoke sensor FGSS-001 does not work any more.
What's update is made on zipabox for that function does not work any more?
In second, it's make another problem, as zwave rang can not be detected any more, the smoke sensor beep as offline detected. Event if temperature are reported.
I think that zwave function for range detector (initiated by a device) is not any more available on zipabox.
Nicolas
I have exactely the same issue with Fibaro smoke detector.
- Testing zWave range has a negative result (as if the zWave network was not detected, even if the sensor is less than 3m from the zipabox without obstacle in between)
- Sensor beeps from time to time as if it can not communicate with the controller.
- temperatures are reported to the zipato
no news? is there a big bug on zwave network with zipabox that some zwave function like range tester isn't functional?
Hello, I still have the issue...
Please let us know at least if "range testing" is functional with zipato.
