ZME_05460 inclusion problem
Oliver Schwab shared this problem 11 years ago
In Progress
Hi there,
as I am quite in need for a wireless switch i bought the ZME_05640 after checked this board if it is supported. It is stated that the inclusion is quite tricky, but will work due to a special procedure.
I have now tried a lot of times to inclued it, but I failed.
So any help is highly appreciated - thanks!
Regards,
Oliver
Hello Oliver,
pressing the "Include" button for 2 seconds will include this device into a Z-Wave network. Also please make sure your device is close to the Zipabox during inclusion.
Triple clicking on either the button "€œDown"€ or the button€ "Up" will issue a Node Information
Frame and keep the device awake for 2 sec afterwards.
Hope this helps,
Hrvoje
Hi Hrvoje,
thanks for your help. After several attempts I finally could include it, but it is recognized as 4036. Unfortunately I also cannot use it as a switch as it doesnot react on the triggers. I also cannot use it in rules as on/off switch as this option is missing.
Any idea about this?
Regards,
Oliver
Hi there,
no idea? I tried to exclude the Switch, but this failed too.
Regards,
Oliver
Is there anyone out there already sucessfully using this controller??????
Regards,
Oliver
