What is the correct way to control multisensor settings?
Jki shared this question 11 years ago
I have two multisensors, Aeotec DSB05-ZWEU and TKB TSM02. Both have too long reporting interval, Aeotc 4hrs and TKB 6hrs. Regardless what I set up in configuration tab for sensor. User manuals skip this setting thing nicely, and move responsibility to Zwave network controller... TKB may have issue in two dip switch setting, because there is no explanation, where they must be, when is allowed to get settings from controller. Aeotec have not any switches, than join button.
Is there anywhere any explanations, what I can do with rounded part settings?
Report interval settings won't do anything. It is always 6 hours.
Multisensor%20config
Am I the only one, who has problems with multisensor settings? No tricks needed any other multisensor?
Now, with latest firmware 1.18 Aeotec works almost correct. Only, if I disable motion detector, all reports are disabled. When motion detector is enabled, it will send reports at given intervals. Without need to motion detector, it could be better for battery life, if it allows let it disabled.
But with TKB, I still need some help... I found a bit better manual for it, but I can't get it obey me. There is 2 dip switches, and if they both are off, it should be "program mode". If I figure out correctly, then it should get settings from controller (Zipabox). Also those Operation mode and function switch bits. In the picture above, there is bit4 and bit5 "set" by default. When I clicked them "off", there is not any more possibility to set more bits "on", than only one. Setting up needs to get several bits up, not only one, I think...
TKB sensor needed battery was taken out for a while, and then start the inclusion sequence again from the sensor. Which was a bit difficult, because it is located 100km away from here... Not very "remote control", if you need to be beside, when controlling. But now it reporting also temperature almost correct interval. Which now varies from half an hour to one and a half hours, when setting is 30min.
Now left is only control word setting, how to set more than one bit...
"remote control" is some kind of issue anyway, because at here, i already have few happening, when i had to do power cord reset to Zipabox to got it back controlling. But is it new topic worth, we'll see.
Looking exactly for the same, hope you can help me in meanwhile how to fix the long interval?
