Virtual Alarm - Alarm Widget: invalid Pin
Peter Frank shared this question 3 years ago
I created an Virtual Alarm Partition in V3. It worked well with the default 0000 Pin.
Then I put the Alarm-Widget an my mobile-Screen. It also worked well.
Next I changed the default Pin to an individual Pin:
The V3-App worked well with the new Pin, but the Widget says: Invalid Pin.
I followed the directions in this forum, logged out, logged in, created new Pin, even deleted the Alarm-Partition and build a new, but the result is the same: the Mobile-App works proper, but the nice Widget says invalid Pin!
Perhaps someone has an idea?
Thanks for your answer,
Yes, i synced before every logout/login. But i allways used the default Pin or one of my older favoured Pins.
Then i tried a new Pin (1111) - and it works! After that i changed to a new -never before used- Pin and the Widget as well as the V3 mobile App works!
I don't no why, but it seems, the widget don't work if you change the Pin and enter an earlier used number.
