Programming
wich protocole, language... Can i use for writting my own interface. Did you have an dll file to do that. Or maybe command line or http request.
I would write an asp.net interface... Then an .net dll will be perfect for me. Did you have?
Thank you
I am sure that others here will give you a definitive answer but please remember that there is no local API with Zipato.
The design philosophy is to use cloud services. This means that the only interface you have is a REST API not a Microsoft API. Writing your own interface is therefore not really possible unless you simply want to wrap the REST API into a set of local classes in order to develop something.
/Marcus
/Marcus
Thank you
Why not if the REST api is complete. I use asp because t'ils more simple for me to use iis server in my house. But i would writting an UI in javascript and .net only for some function on server side.
Where can i found doc about this api ?
Thank you
Here you can find it https://my.zipato.com/zipato-web/api/
