New skin dont work
Zipato Control Center not responding ..
Is this a temporary problem?
The new skin looks very tidy and minimalist. Unfortunately I don't seem to be able to create new rules nor edit existing ones. I can delete rules and it appears I can turn devices on and off at will.
In "Events" I no longer seem to be able to see all the devices in a specific room.
There is no documentation on the new UI, everything seems to relate to the previous UI. How can I revert back to that and get things working again?
More over, it's unusable with IE or Chrome (scroling is KO). Only Firefox is nearly working with this new user interface.
Another issue, many settings of devices are inacessible.
Zipato please correct those bug. This new user interface is a good news but it has not been debug at all .... :-(
Please hurry
Please hurry
we will now working on this one constantly in order to fix whatever you find.
However, if you really don't like it, for now you can still access the old one at:
https://my.zipato.com/zipato-web/Dashboard
Regards,
Regards,
Again and Again . . .
And i add that my widget camera still loading but never work ! !
IF you need camera in the meanwhile, use the old one please.
Where is the rebuild network command?
Lot of nice things in there now, but lot of bugs too. Also very hard to get old dashboard back, wants to go to this new one instead. ..../dashboard# seems do the trick.
hello, nice interface but it is impossible to change the settings, when saving is impossible, plus I still can not use my IP cameras.
I began to seriously regret my purchase ZIPATO!
great another Beta release of zipato, and i that just got things back to working after last firmware bugs got fixed
Why not release it as a option to log into the new gui and keep the old one as default, would probably make people less irritated over the quality of your releases.
BTW timing of the release, is it really best time of the year to release right before the holiday when everyone is leaving there home in the hands of zipatos box?
still have hope for zipato, not saying that your compositors are doing any better work regarding quality of releases.
If i could take the zipabox and combine it with vera's plugin support it would be best thing out there.
You should quikly add CLEAR link to old dashboard, or change default logging into old one.
