Fibaro FGS221 - parameter 14 ( 0 - momentary switch)
Interested shared this question 11 years ago
Hi.
I would like to use Fibaro FGS221 for opening and closing garage doors.
To use FGS221 relay as momentary switch, I have to change parameter 14 to 0.
But Zipato BOX does not support parameter 14.
Is there any other way or solution ????
TNX again.
it does not matter, I can use FGS221 without parameter 14
Can the inputs on the FGS221 be used as a inputs for a wirred magnetic door sensor somehow?
i'm sorry but i don't understa how you say that it doesn't matter,
i'd like to set up an operation using a swith and not a button.
it says that i've to set up parameter 14..
