Climate - Weekly program issue, using new GUI
Using the new GUI, the climate weekly program is not well displayed
Thank you
Document1.pdf
I tried to redefine the weekly program for one of my climate with this new UI but after it does not work properly...
To correct my climate, I had to reconfigure it with the old UI.
Other point, the configuration made in the new UI cannot be seen in old UI.
In the old UI, we can see the old climate configuration.
Tested again, not fixed(repaired, if better).
If i make a manual change to temp, and press "permanent hold", it shows
that it is changed. But really not, log out and again in, it is back in
weekly program temp, and shows still "permanent hold". For example.
Hello Jki,
I am unable to replicate your issue.
Which firmware are you using?
Do you still experience the same issue?
Hello Jki,
My firmware is 0.9.999.2a, but it's working since yesterday night.
The climate/thermostat still not work, as it should...
A bit a challenge to my not so good english, but lets try... If i manually increase temp from the slider, it shows new setting and switch radiators "on". I click the "permanent hold". Then after logging out, and again in, it shows again weekly programmed temp, not new temperature and radiators are "off". However, "permanent hold" shows still active.
Another thing is, if i want program whole week, for example, "away", it is impossible. It won't save the program. Some time i can change one day to "away", but then, if i try change another, previous go back to "comfort". If i drag whole week to "away" and click "save", there is always only sunday "away". I have made whole week program from old dashboard "away", and it is "active" program, fortunately. Changes from new dashboard seems not overriding this setting. It should be that way, until new thermostat is usable.
Hello Jki,
I am still unable to replicate your issue. Open ticket so we can troubleshoot-it further.
Hello Jki,
The climate/thermostat is still unusable in new UI.
My experiences from last 24h tells, that you should not create new thermostat, trying to adjust the current one, or maintain it any way from the new UI.
Perhaps it works for somebody, but mine do not.
When created and adjusted from old UI, it works correctly. (still... I'm sensing, that there is coming some conflicts between old and new UI)
I have the same issue as Jki refered above..
Can`t use the new GUI to set ut temperature and permanent hold function does not work.
In old GUI it works.. This tested standing in the room and watching the power turn on and off.
So, new GUI does not work !!
ALSO, when turning heath up above 21,5 degrees, the new GUI drops back to 21,5. In old GUI the temperature shows correct f.ex 23 degrees as shown i pictures below
See picture
This issue have been present after new GUI in christmas..
See picture
Hello Magnus,
Please try to update your box with new firmware and then see if the issue reappers.
Hello Magnus,
