TZ66 D
Stephane Rochette shared this problem 11 years ago
This module swicth off by itself with no reason.
Did you check the events that the switch was triggered or "target" device was triggered.
Could also be the case that the flipper (switch button) is stuck
No way the switch button is stuck.
How can I see the difference swith or target was triggered?
Sorry, mistake.
The switch button is not stuck.
How can I see the difference between: switch or target was triggered?
Or did you already created a rule?
There is no rule on that device.
