All my 433 devices are out of order
Pat@ shared this problem 11 years ago
In Progress
after a off/on of the box, all my 433 devices are became out of order: SOMFY rollers, Chacon wall plugs... they are visible but it is not possible to switch them.
The Z wave devices are ok.
The RF433 extension no more working?
Domagoj Pintaric Posted 5 hours ago
HI,
We are experiencing a problem when the ZipaBox reboots the 433 module stops working. We are investigating as to what is the cause and in the mean time you can try this quick fix: reboot the box but with out the ethernet cable plugged in. When the box reboots it's will blink green, then plug the ethernet cable back in and wait until the light is steady green. Try if your 433 works after this.
Regards,
Domagoj
the fix worked for me too.
I confirm, this trick (it is not really a fix !) is working, waiting a new stable solution !
Hello everyone,
If you still have troubles with 433 devices, please go to API (in the top-middle of the screen), in a new window click on the Firmware and when the drop-down appears click on "Get" button beside "/firmware/upgrade/beta" and then click on "Try it out!" button. Your box will be updated onto the Beta Firmware which has a fix for 433MHz networks.
Hrvoje
