Conect to Nexa devices
Fredrik Elofsson shared this problem 10 years ago
I can no longer control all my Nexa devices.
What could have happened?
I've tried to connect them again with Zipaboxen but nothing happens.
I have restarted Zipaboxen without result.
Do you have any advice for my problem ???
Replies (6)
Same problem.
I had this problem when I first started my new box some 4-5 days ago. I had to make a hard reset and then it was downgraded to a lower FW made a new upgrade and now my NEXAs are working. Had some OFFline issuses some days ago aswell
Hi again
I changed the firmware and it works for a while but now I can not control Nexa devices anymore.
I'll change the firmware again, or what could be wrong?
And then, none of my rules work anymore what could be wrong with that?
Ångra ändringarna
The "/firmware/upgrade/beta" option helped for me.
I have tried to update the firmware . After the upgrade , it's much worse now. Have 20 pieces of Nexa installed in the house and that is all one unit that does not start on the first try .
it is possible to downgrade from 0.9.999.2i then this version is not reliable .
Previous problems related to long distance.
Hello Carl-Johan,
if you wan't to downgrade form beta version please go to API (in the top-middle of the screen), in a new window click on the Firmware and when the drop-down appears click on "Get" button beside
"/firmware/upgrade/release" and then click on "Try it out!" button.
Hrvoje
